JLee25
Contributor
6 years agoHDMI Long Lock Time
Hi, I am facing the Rx long lock time issue on HDMI 2.0 resolution. I am using Cyclone 10 GX + Quartus 19.2. Do you know how to reduce it? Thank you! BRs, Johnson
Deshi_Intel
6 years agoHi Johnson,
Thanks for pointing out the long lock time limitation in C10 GX HDMI design example doc.
I want to clarify further with you first before I check with Intel Engineering team on long lock time issue fix update.
- May I know are you using just HDMI IP or HDMI design example that encounter this long lock time issue ?
- V19.2 : you countered long lock time issue
- You also mentioned previous Quartus version doesn't face this issue. Can you let me know which previous Quartus version is working fine ?
dlim
