HDMI IP Data and clock settings
HI,
I didn't hear back further from you.
Hopefully my earlier explanation is clear to you.
For now, I am setting this case to closure.
dlim
Sorry
Due to covid 19 could not reply in a timely manner.
I would like to know the following.
For a 4k 60fps the following values are used :
pixel clock : 594MHZ
Total horizontal count : 4400 pixel clocks
Visible pixel count : 3840
Horizontal front porch : 176
Horizontal back porch : 144
Horizontal sync : 88
Total vertical count : 2250 vertical lines
Visible line count : 2160
Vertical front porch : 8
Vertical back porch : 72
Vertical sync : 10
The IP (on Cyclone 10GX) accepts 2 pixels per clock.
what would be the correct clock frequency and count values the IP needs to receive in order to operate correctly at 4k 60 fps.
Another issue I am having is what are the infoframes values I need to set for the IP to operate at a 4k 60 fps, if at all. Does the IP need the info frames in order to output the mentioned resolution.
And last but not least I would like to know what I am suppose to see on the transceiver output of the clock signal since when connecting this line to a scope I do not see a clock signal.
