RonenP
5 years agoHDMI IP Data and clock settings
Hi
I am trying to set the HDMI IP to work at only one resolution of 4k 60fps on a cyclone 10 GX (i.e. HDMI 2.0).
According to the HDMI specs. the pixel clock has to be at 594MHZ with 4400 total ...
Deshi_Intel
5 years agoHI,
HDMI IP has its own encoding and decoding logic and the HDMI example design page 23/24 is telling you the right clock frequency that you need to supply to the HDMI IP
- The most crucial clock will be the link_speed_clock (ls_clk) and video_data_clock (vid_clk)
Assume your 4k Pixel clock = HDMI TMDS clock = 594MHz
Then you can basically use the formula shown in page 23/24 to calculate required ls_clk and vid_clk
ls_clk = TMDS clock frequency/ Symbol per clock = 594/2 = 297MHz
Assume you are using 10 bit per colour with colour depth factor = 1.25
vid_clk = TMDS clock/ Symbol per clock/ Color depth factor = 594/2/1.25 = 237.6MHz
You can also checkout HDMI IP user guide doc if you would like to learn more about HDMI IP usage
dlim
