RonenP
5 years agoHDMI IP Data and clock settings
Hi
I am trying to set the HDMI IP to work at only one resolution of 4k 60fps on a cyclone 10 GX (i.e. HDMI 2.0).
According to the HDMI specs. the pixel clock has to be at 594MHZ with 4400 total ...
Deshi_Intel
5 years agoHi,
You can checkout the HDMI related clocking scheme calculation at table 14 (page 23, 24) of below C10 HDMI design example doc.
dlim
RonenP
5 years agoHi Deshi
Thank you for the quick reply.
I looked it over yet I still am confused.
In order to send 4k60fps the pixel clock should be 594Mhz based on the following resolution values :
4400 total horizontal count and 2250 total vertical count.
Yet the IP accepts 2 symbols per clock. What values do I need to modify for the horizontal, vertical and pixel clock in order to get the 4k60fps ?
Thank you for your time
