JWang21
6 years agoHDMI compliance issue
Currently our design (using 10AX115) is suffering a HDMI compatibility issue with a certain video source. The HDMI Rx is Coretronix's in-house IP. The Tx is a specific video box. We already know tha...
Deshi_Intel
6 years agoHI Jay,
Pls see my comment below.
- When the video source has larger jitter...
- This is a very subjective question and literally depend on your actual design implementation (timing constraint, fitter placement, which PLL location usage and etc)
- Anyway, you can refer to A10 datasheet table 38 and table 39 for A10 fPLL and IOPLL spec guideline
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_datasheet.pdf
- Do take note of NOTE65 : A high input jitter directly affects the PLL output jitter. To have low PLL output clock jitter, you must provide a clean clock source with jitter < 120 ps.
- The fPLL is set to "CASCADE SOURCE" in FPLL MODE in Platform Designer...
- I reviewed A10 HDMI reference design and I can see that it's using PLL cascade mode as well. The only difference is the reference design is using IOPLL instead of fPLL.
- You can take a look of the reference design as well. checkout hdmi_rx_top.v design file in <project>\ip\hdmi_subsys\hdmi_subsys_alt_hdmi_example_design\alt_hdmi_example_design\rtl\hdmi_rx
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an776.pdf
dlim
