AleCampla
6 years agoGoal: 1GbE on Stratix 10 MX dev kit. With the Triple-Speed Ethernet IPcore (10/100/1000-Mbps Ethernet MAC and 1000BASE-X/SGMII PCS with Optional PMA) the GXB option is not available in Intel Stratix 10 devices. How to get this done via QSFP?
I am trying to setup a 1GbE communication between the Stratix10 MX DevKit and my machine. I have already these two connectors available: QSFP to SFP SFP to RJ45 I thought it would have been pos...
Deshi_Intel
6 years agoHi,
We don't have the exact Ethernet 1G reference design for Stratix 10 MX dev kit board but we do have Ethernet 1G reference design for other Stratix 10 dev kit board as reference.
Triple-Speed Ethernet (TSE) IP is legacy IP we used to suppot 10M/100M/1G application that typically paired with RJ45 connector.
- I found one reference design targeting S10 GX dev kit as below
- https://fpgacloud.intel.com/devstore/platform/19.3.0/Pro/an-830-intel-fpga-triple-speed-ethernet-and-on-board-phy-chip-reference-design-for-intel-stratix-10-devices/
Likewise if your interest is more on using SFP connector then perhaps you can checkout the multirate PHY IP reference design instead of using TSE IP. This design is targeting S10 SI dev kit board
- https://fpgacloud.intel.com/devstore/platform/17.1.0/Pro/1g25g-ethernet-design-example-for-intel-stratix-10-devices/
dlim
