GMII to RMII Converter usage restrictions
The GMII to RGMII converter core is supported in Arria 10 check this link https://www.intel.com/content/www/us/en/docs/programmable/683130/24-3/device-support.html
However, cannot use the GMII to RGMII Converter with the Triple-Speed Ethernet. Check internal message below:
Our internal team replied that RGMII is supported for our Arria 10 SoC HPS EMAC.
However, to use the Triple-Speed Ethernet IP, the RGMII interface is not supported in Intel Arria 10.
So the answer is no, you cannot use the HPS GMII to RGMII Converter with the Triple-Speed Ethernet, since the RGMII interface is not supported for Arria 10.
Check this KDB as well: https://www.intel.com/content/www/us/en/support/programmable/articles/000077033.html
Sheng
Hi thanks for confirming that the IP is supported in the Arria 10.
However, I am confused on the second part of the answer.
Based on the KDB link. RGMII should not work at all for Arria 10 because it fails timing.
So how can the IP work with the HPS but not the Triple Speed Ethernet?
Thank you
