dsun01's avatar
dsun01
4 years ago
generic Serial Flash Interface tested on Arria10 dev board
Dear Support/Expert,
I am following ug_gen_sfi_683419-666881 step by step to create a Quad_SPI on Arria10 dev board.
I need learn how this SPI works and going to custom it to a none flash operation. so I confir the parameters as
disable dedicated active serial interface( checked)
enable SPI pins interface (checed)
use byteenable for CSR( checked)
platform designer can generate HDL no problem, Quartus pro 21.3 compiles OK
but will I generate the Nios2 project, hello from nios2. I got the following errorw.
Description Resource Path Location Type
#error Missing altera safeclib. Please enable it in BSP Software Package. intel_generic_serial_flash_interface_top.c /helloworld_bsp/drivers/src line 282 C/C++ Problem
#error Missing altera safeclib. Please enable it in BSP Software Package. intel_generic_serial_flash_interface_top.c /helloworld_bsp/drivers/src line 672 C/C++ Problem
make: *** [obj/drivers/src/intel_generic_serial_flash_interface_top.o] Error 1 helloworld_bsp C/C++ Problem
recipe for target 'obj/drivers/src/intel_generic_serial_flash_interface_top.o' failed Makefile /helloworld_bsp line 573 C/C++ Problem
if I double click the error, it will point to this code. ( intel_generic_serical_flash_interface_top.c)
I attached the archive. hope someone who familiar with the quad spi give me some suggestion.
#ifdef SAFECLIB
ret_code = memcpy_s(((void*)&word_to_write) + padding, bytes_to_copy,
((void*)data) + buffer_offset, bytes_to_copy);
if(0 != ret_code)
return ret_code;
#else
#endif
  • dsun01's avatar
    dsun01
    4 years ago
    Hi Ash_R_Intel,
    I will give it a try, it will take sometime because I am still learning how to use it. thank you very much.
    David
    • dsun01's avatar
      dsun01
      Hi Ash_R_Intel,
      David
  • Ash_R_Altera's avatar
    Ash_R_Altera
    Do you have any update on this case? Were you able to resolve the issue with provided suggestion?
    • dsun01's avatar
      dsun01
      Hi Ash_R
      I accidently clicked myself post as a solution. sorry. it solved, please close this topic.
      Thank you very much
      David
      • meenalkb's avatar
        meenalkb
        What was the solution?
    Ash_R_Altera
    Glad to know that the issue was resolved, so closing the case. However, for other community user's knowledge, request you to add your observations here and how did you resolve it.
    Thanks and regards
