xgiaime
6 years agoGeneric Serial Flash Interface for single SPI - how to connect MISO, MOSI?
Hello, I implemented the Generic Serial Flash Interface to connect to a W25Q80DVSSIG TR 8Mb serial flash. I would like to use simple SPI: so I have CLK, nCS, MISO and MOSI to connect. The HDL gener...
CBlow
4 years agoHello,
I have a customer with the same question. The SPI flash W25Q01JV is a 1Gbit flash with single DI and DO.
The Generic Serial Flash IP user guide says it supports single, dual and quad SPI flash, but there is no selection in the IP wizard to set this. The Generic Serial Flash IP appears to support only quad-SPI. How does the user configure this IP for single-SPI?
Thank you.
