Generic Serial Flash Interface for single SPI - how to connect MISO, MOSI?
Hi Giaime Ugliano,
Sorry for the late. The IP supports Single, Dual and Quad mode. No setting is needed on the IP for Single, Dual and Quad mode. It is on the flash. If your flash support single, dual and quad mode, you will need to enable it on flash using Generic Serial Flash IP.
I just checked the flash datasheet, seems like it has 4 data I/O pin as well. You can just connect the 4 data I/O pin with the QSPI_PINS_Data.
Thank You
Hello Bruce,
thank you very much for your reply!
The issue is, the PCB is already done connecting only MISO and MOSI to the FPGA. This is because the Flash itself defaults to single SPI mode, if you don't use the special instructions.
In this case, how do you think it's best to connect the pins? They're INOUT type, while my MISO is IN and MOSI is OUT types. How to handle that?
Thank you very much in advance,
best regards
Giaime
