9 years ago
generating the Matrix_mult IP by using ALTERA_FP_MATRIX_MULT
I generated a matrix_mult IP by using ALTERA_FP_MATRIX_MULT. The system showed the following information.
Info: Saving generation log to /home/tan/temp/matrix_mu/unnamed/unnamed_generation.rpt
Info: Starting: Create block symbol file (.bsf)
Info: qsys-generate /home/tan/temp/matrix_mu/unnamed.qsys --block-symbol-file --output-directory=/home/tan/temp/matrix_mu/unnamed --family="Stratix V" --part=5SGXEA7H3F35C3
Progress: Loading matrix_mu/unnamed.qsys
Progress: Reading input file
Progress: Adding fp_matrix_mult_ii_0 [altera_fp_matrix_mult_ii 16.0]
Progress: Parameterizing module fp_matrix_mult_ii_0
Progress: Building connections
Progress: Parameterizing connections
Progress: Validating
Progress: Done reading input file
Info: qsys-generate succeeded.
Info: Finished: Create block symbol file (.bsf)
Info:
Info: Starting: Create HDL design files for synthesis
Info: qsys-generate /home/tan/temp/matrix_mu/unnamed.qsys --synthesis=VERILOG --output-directory=/home/tan/temp/matrix_mu/unnamed/synthesis --family="Stratix V" --part=5SGXEA7H3F35C3
Info: unnamed: Generating unnamed "unnamed" for QUARTUS_SYNTH
Error: fp_matrix_mult_ii_0: Error starting the process ([/home/tan/altera/16.0/quartus/../hls/bin/internal_matrixmult_helper, -march=altera, --RTL-only, --fp-relaxed, -o, matrix_mult, --device, Stratix V, --clang-arg, -generate-altera-ip, --fpc, -I., /home/tan/altera/16.0/ip/altera/dsp/altera_fp_matrix_mult_ii/matrix_mult.cpp]): Cannot run program "/home/tan/altera/16.0/quartus/../hls/bin/internal_matrixmult_helper" (in directory "/tmp/alt7282_5396898303674959013.dir/0001_fp_matrix_mult_ii_0_gen"): error=2, No such file or directory
Error: fp_matrix_mult_ii_0: IP geneneration failed at file discovery, please tell Altera
Error: can not find channel named "couldn't open "/tmp/alt7282_5396898303674959013.dir/0001_fp_matrix_mult_ii_0_gen//matrix_mult.prj/altera_fp_matrixmult_internal_hw.tcl": no such file or directory" while executing "read -nonewline $fd" (procedure "discover_files" line 5) invoked from within "discover_files $proxy_file_set $tmp_dir" (procedure "generate_all" line 15) invoked from within "generate_all $output_name QUARTUS_SYNTH" (procedure "generate_quartus_synth" line 2) invoked from within
"generate_quartus_synth unnamed_fp_matrix_mult_ii_0"
Info: fp_matrix_mult_ii_0: "unnamed" instantiated altera_fp_matrix_mult_ii "fp_matrix_mult_ii_0"
Info: unnamed: Done "unnamed" with 2 modules, 1 files
Error: qsys-generate failed with exit code 1: 3 Errors, 0 Warnings
Info: Finished: Create HDL design files for synthesis
I checked the contents in the directory /tmp/alt7282_5396898303674959013.dir, and found that it is empty. My computer environment is shown as follows:
OS: CentOS 6.5
FPGA tools: Quartus Prime Standard version 16.0.0 build 211
I login as root, and install the Quartus file, and run it. The user file folder is on the home directory.
Please tell me how to fix the error.
