11 years agoFIR and CIC MegaCores Altogether
Hi, I have instantiated FIR II MegaCore as a Pulse-Shaping and upsampling by 8 filter, now I want to use CIC MegaCore after FIR to interpolate the signal... I didn't use Back Pressure feature in...
11 years agoI changed the CIC clock to 10 MHz, it was 100 MHz... output of FIR is around 1.42 MSPS and interpolation factor is 7.
And this is my configuration: http://www.alteraforum.com/forum/attachment.php?attachmentid=10272&stc=1 In SignalTap I got this: http://www.alteraforum.com/forum/attachment.php?attachmentid=10273&stc=1 You can see that CIC is producing samples like bursts (dout and out_valid signals) And it is accepting samples all the time (RRC: ast_source_ready signal) RRC is driving its output_ready signal along with CIC's out_valid. (This is strange) I used edge detector to drive CIC's in_valid signal. All that resulted in this: http://www.alteraforum.com/forum/attachment.php?attachmentid=10274&stc=1 After deleting samples that aren't associated with validity signal... I got this: http://www.alteraforum.com/forum/attachment.php?attachmentid=10275&stc=1 Which I need to have as a direct output of the CIC. I feel that outputs of FIR and CIC should be swapped... I mean FIR must provide data as bursts and CIC must spite out samples continuously. I think there is something to do with what you've just mentioned... don't you think that Back Pressure should handle this? It's enabled!
