11 years agoFIR and CIC MegaCores Altogether
Hi, I have instantiated FIR II MegaCore as a Pulse-Shaping and upsampling by 8 filter, now I want to use CIC MegaCore after FIR to interpolate the signal... I didn't use Back Pressure feature in...
11 years ago --- Quote Start --- I do have it... but I can't simulate it... however, I used SignalTap to observe the output... it was distorted. I connected "in_ready" output signal of CIC to the input "ast_source_ready" of FIR. I don't think there is much to do. Or is there? --- Quote End --- when cic is ready for input the fir will then produce ouput late due to FIR latency. You need to have CIC input ready when it asks for it. I think a fifo will do. write to fifo FIR output on valid out and read fifo on CIC in_ready with enough fifo depth.
