TJind
7 years agoFFT Output is missing one sample when sink valid is not continuously asserted
Hello, We are using Quartus prime lite v17.1 to simulate and verify the FFT IP core. FFT IP Config - 1) Variable streaming mode 2) Fixed point FFT 3) 64 points 4) 16 bit sink data As per o...
CheepinC_altera
7 years agoHi Tarang,
Thanks for your update. For your information, this issue is related to the FFT IP instead of Quartus version.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/kdb-filter.html
For other known issues with FFT IP core, it is recommended to you to visit the following KDB search link, then search "FFT" to check on the KDBs related to FFT.
Chee Pin
