TJind
7 years agoFFT Output is missing one sample when sink valid is not continuously asserted
Hello, We are using Quartus prime lite v17.1 to simulate and verify the FFT IP core. FFT IP Config - 1) Variable streaming mode 2) Fixed point FFT 3) 64 points 4) 16 bit sink data As per o...
CheepinC_altera
7 years agoHi,
I would like to apologize for the delay in response. It seems like I encounter some issues with notification reaching my mailbox. Sorry for the inconvenience.
As I understand it, you are observing some issues related to the FFT IP missing sample when sink valid is not continuously high. For your information, this seems to be a known issue and you may refer to the KDB as following:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/ip/2019/why-is-the-last-output-frame-of-the-intel--fft-ip-core-missing-e.html?wapkw=why+is+the+last+output+frame+of+the+intel+fft+ip+core+missing
As a workaround, you may configure the Output Order in FFT IP to be Digit Reverse to see if works for you. Alternatively, you may need to hold the sink_valid high continously. Sorry for the inconvenience.
Chee Pin
