17 years agoFFT Mega Core IP
I am working on FFT MegaCore IP. I would like to give 64 points to the generated file and get the output using Altera DE2 board not the simulation. I built a top level file.v to pass the inputs...
17 years agoCheck the attachment. i m using a ROM to provide inputs to controller. controller genrates proper SOP, EOP and Valid signals and passes them to FFT IP Core. the results of the IP Core are the also used as output of the controller. the symbol file attached will explain it all
Regards.- SYadl26 years ago
we are facing issues with out put signals from FFT in board testing. But everything working fine in simulation.
is your issue is solved??
