17 years agoFFT Mega Core IP
I am working on FFT MegaCore IP. I would like to give 64 points to the generated file and get the output using Altera DE2 board not the simulation. I built a top level file.v to pass the inputs...
17 years agoI test the output from the FFT using the LED on the FPGA board.
Unfortunately, the LED are always off == there is no outputs. I am also test the outputs using a logic analyzer. Also, the outputs are always zeros. I will attach the top level file here. If you do not mind please browse it and tell me what is wrong, please.
