Prajwal_RJ146
2 years agoFailed in establishing communication with Ethernet physical layer trans-receiver.
I'm using DP83867 (Ethernet physical layer trans-receiver.) and cyclone V 5CEFA7F27I7 FPGA. i can able to see the LED glowing at trans-receiver IC and RJ45 port when ethernet cable is connected at R...
ZiYing_Intel
2 years agoHi,
Will you please help to read out the following registers when this error occurs?
- MAC registers: Rev (0x0), command_config(0x2)
- PCS registers: control(0x0), status(0x1)
zying
