zjj
3 months agoF-tile ethernet hard ip in agilex7
I generate 200G ethernet F-tile hard ip that base on agilex7, the IP configuration as follow: Our current test setup uses our custom development boards interconnected with Mellanox CX-8....
- 2 months ago
The recommended workaround is to re-apply the TX pause configuration in software after hot-plug/link recovery. In practice, after the optical module is reinserted and the link comes back up, rewrite TX_PAUSE_EN (tx_pause_en, offset 0x122C[8:0]) because that register controls the TX PAUSE / TX PFC enable bits and can end up cleared.
Pavee
zjj
3 months agowe use SFP112 and DAC cable, but it still fails to link up.
paveetirrasrie_Altera
2 months agoThanks for the update.
Can you please try the suggestion I provided earlier and do let me know if it helps.
Pavee
