Experiment with S-10 Transceiver IO Terminations
Hi HPB,
Thanks for your update. Glad to hear that by setting the slew rate to the highest is helping to improve the BER in your board setup. I understand that the existing impedance mismatch is due to the devkit trace impedance. Please note that in your final board implementation, it is still recommended ensure impedance matching with trace impedance and TX/RX OCT.
Thank you.
- HBhat27 years ago
Contributor
<Glad to hear that by setting the slew rate to the highest is helping to improve the BER in your board setup>
This is Stratix 10 SoC Dev kit (L-tile ) and FMC loopback card setup
<Please note that in your final board implementation, it is still recommended ensure impedance matching with trace impedance and TX/RX OCT>
Yes. It is understood clearly.
Thank you..
With regards,
HPB
