HBhat2
Contributor
7 years agoExperiment with S-10 Transceiver IO Terminations
Hi, I am performing some experiment with S-10 SoC Dev kit (L-tile). I am using FMC loopback cards to check the behavior of SERDES so as to use for my final requirement. My goal is to connect a dev...
CheepinC_altera
7 years agoHi,
Regarding the slew rate control settings, as I understand it from the user guide, 0 = slowest and 5 = fastest. There seems to be no specific specs in term of seconds in the user guide.
Thank you.
Chee Pin
- HBhat27 years ago
Contributor
I carried out the experiment with TX& RX termination set to 85 ohm and Slew rate control = 5. With this I am seeing the eye opening.
attached the snapshot of the same. Eye is captured with PRBS7. Also, I checked the BER for PRBS31 by transmitting around 10^12 bits, but BER remained 0 in the TTK.
With regards,
HPB
