Experiment with S-10 Transceiver IO Terminations
Hi HPB,
Regarding the TX analog settings, apart from the VOD and pre-emphasis, there is another parameter - slew rate control. However, based on my understanding, generally VOD and pre-emphasis would have more significant impact to signal integrity. In your case, I think you would need to look into using matching impedance since the auto-sweep is unable to get any acceptable BER for you. Sorry for the inconvenience.
Chee Pin
- HBhat27 years ago
Contributor
Hi Chee Pin,
Thank you for hinting towards slew rate. Let me check that as well.
I think this is one of the aspect which I missed. In all my previous tests, Slew rate control was set to '0'. Just now I gone through the XCVR user guide and found that Slew rate control is set o 5 for Gen2 PIPE and Gen3 PIPE.
Also, I want to know the definition of values of slew rate control ( 0 to 5). i.e. what is the meaning of slew rate control = 0, 1 etc..
With regards,
HPB
- CheepinC_altera7 years ago
Hi, Regarding the slew rate control settings, as I understand it from the user guide, 0 = slowest and 5 = fastest. There seems to be no specific specs in term of seconds in the user guide. Thank you. Best regards, Chee Pin
