snehal_p
Contributor
3 years agoEthernet detection Issue
Hello, PFA block diagram, we have Ethernet RMII Interface on the cyclone V board is connected through FPGA IO. We are using Triple ethernet ip in 10Mbps mode to interface. Clock 50 Mhz is gi...
paveetirrasrie_Altera
3 years agoHi Snehan,
I believe you're using time limited sof. We do have time limitation while using time limited sof. Below attached picture has the details.
Is the ethernet not detected at all or suddenly it held low? Is there any other evaluation mode IP is included in your design?
- snehal_p3 years ago
Contributor
Hello Paveetirra_Srie,
We are using time limited sof. Can you reshare the picture you shared above as it is not loading. Ethernet is not detected at all. We are using triple speed ethernet ip.
snehal_p
