MDehp
7 years agoErrors when using the "MAX 10 Single-Port Triple Speed Ethernet and On- Board PHY Chip Design Example User Guide"
Hi all, When I use the MAX 10 Single-Port TSE reference design. I encounter some problems. I use version 18.0 of the reference design in Quartus 18.0. First of all when I open the design in platform...
Deshi_Intel
7 years agoHI Mansur,
I am not sure which doc that you are referring to but in attached Max10 dev kit user guide doc (page 18, table 4-18 HSMC schematic signals), I can definitely see more than 18 data bus pins on HSMC that can be used for 2.5V IO standard.
Can you double check again ?
dlim
MDehp
7 years agoHi dlim,
Yea there is more than 18 data pins, but the Mapping with the HSMC specifications isn't right.
But I have already solved it by using the schematic of the MAX 10 development kit for the pin mapping.
Kind regards,
Mansur
