Errors when using the "MAX 10 Single-Port Triple Speed Ethernet and On- Board PHY Chip Design Example User Guide"
Hi Dlim,
Yes it's still about the "Avalon-ST reverse Loopback Test" TEST_ST_LB 1000M.
I already tried to view the TX channel and RX channel signals on a scope, by measuring on the HSMC pins of the MAX 10 Development kit.
But I couldn't see any of the signals except for the FIFO RX and TX clocks. On the other pins I only detected noise.
This was the case when I used the "Standard Differential Host Pinout" of the HSMC Specification. But I geuss only the "Standard Single-Ended Host Pinout" is supported by the MAX 10 Development kit.
But now that I am trying to map the Avalon-ST signals of the TSE MAC according the Single-Ended Host Pinout I discovered that not all pin mapping is documented in the MAX 10 User Guide.
Could you confirm which Pinout I should use for the MAX 10 Development kit?
Kind regard,
Mansur
