11 years agoError while generating DDR2 IP core for CycloneIV in Quartus13.1
Hi all,
Can anybody help me out to remove the following error I am getting while generating the core. ---------- Error (332000): can't read "dqsclksource": no such variable while executing "create_generated_clock -multiply_by 1 -source $dqsclksource -master_clock $dqsclksource $dqspin -name $dqs_out_clockname -add" (procedure "add_requirements_for_instance" line 263) invoked from within "add_requirements_for_instance $corename $inst t board ISI $DDR2_USB_phy_use_flexible_timing" ("foreach" body line 3) invoked from within "foreach inst $instance_list { post_sdc_message info "Adding SDC requirements for $corename instance $inst" add_requirements_for_instance $corename $..." (file "DDR2_USB_phy_ddr_timing.sdc" line 635) ---------- If I comment those lines in .sdc file, I am getting similar errors for other variables. Thanks in advance.No RepliesBe the first to reply
