Error: (vsim-3033) Instantiation of 'msgdma' failed. The design unit was not found.
- 7 years ago
I am using ModelSim Altera Starter Edition 10.3c.
I am also compiling within ModelSim but the Qsys project was created using Quartus Prime Version 17.0.2.
As an update, I realized that the way I defined the TOP_LEVEL_NAME in the mentor. do file was incorrect. Which meant it prevented the msim_setup.tcl script from running the simulation. And when I then went and tried to run the simulation manually, I was doing so without the library inclusions that the tcl script uses.
vsim -t ps $ELAB_OPTIONS $USER_DEFINED_ELAB_OPTIONS -L work -L work_lib -L write_mstr_internal -L read_mstr_internal -L dispatcher_internal -L rst_controller -L msgdma_0 -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclonev_ver -L cyclonev_hssi_ver -L cyclonev_pcie_hip_ver $TOP_LEVEL_NAME
Since it was hard to find information online for how to define these variables, the definition that finally worked was
set TOP_LEVEL_NAME work.user_module_tb
I am now able to simulate. I get warnings that may have to do with the fact that my test bench is still incomplete, but otherwise the MSGDMA is simulating properly.
Hi @VCham ,
Can you share the design ?
Which version &edition of quartus & modelsim are you using ?
Attache modelsim log.
Anand
