KKuhl1
7 years agoError 14566 placiing multiple Transceiver Native PHY IP in Arria 10
Hi I have instantiated a Transceiver Natiive PHY block in my design and it builds fine. When I place a second copy of the IP in my design and connect it to other pins I get the following error Erro...
CheepinC_altera
7 years agoHi,
As I understand it, you observe fitting issue after adding second instance of the Native PHY in you A10 design. There is no issue when there is only one instance in the design. To facilitate further debugging, would you mind to share with me simple test design with only Native PHY instances which could replicate your observation? I would like to perform replication and further look into it to see if can spot any anomaly. Thank you.
