FZhao12
6 years agoError 129037 when compiling core
Error (129037): Output port OUTCLK on atom "ddr_0002:ddr_inst|ddr_pll0:pll0|uphy_clkbuf_memphy", which is a stratixv_phy_clkbuf primitive, is driving one or more illegal destinations。
FZhao12
6 years agoThe problem is solved, you can't connect the following PLL output breaks when instantiating, then compile the first step, then run the pin assignment script file once, and then compile it all, no matter the version, thank you
NurAida_A_Intel
6 years agoGlad to know everything is working fine at your side now. Thank you for sharing 😊
