DRile6
6 years agoError (11666): Device "5CSEBA6U23I7" does not support "Channel PLL"
Hello, I'm trying to instantiate a component of the SDI II Intel FPGA IP as a receiver, but whenever I attempt to compile the design I get the following errors: Error (11661): Design uses HSSI PLLs ...
CheepinC_altera
6 years agoHi,
As I understand it, you encounter some compilation error related to no HSSI PLL supported in the your selected device. For your information, the HSSI PLL is only available in CV GX devices. The device 5CSEBA6U23I7 that you are selecting is not a GX device. This is why during compilation, you will see the error.
Mind share with me further on the specific datasheet which mention about this device supporting HSSI PLL?
Chee Pin
- DRile66 years ago
Thank you. The datasheet made no delineation between GX and non-GX devices, it only listed the Cyclone V - that may be where I misunderstood.
