Enable the Latency Measurement function of Stratix 10 E-tile Transceiver Native Phy
Hi Wang,
I think I figure out the gap between what we are talking about.
The deterministic latency calculation of E-tile CPRI PHY IP is used when you are using CPRI PHY IP instead of Native PHY IP.
For deterministic latency calculation of E-tile CPRI PHY IP, you will need to read different registers from different avmm interfaces.
For example, TxDL is read from CPRI PHY register which is through CPRI PHY reconfiguration interface(32-bit).
This interface is not the reconfiguration interface(8-bit) you saw on Native PHY IP.
If you're only using Native PHY IP, you can only get the DL from deterministic latency measurement interface. Those calculations are not applicable.
Leo Feng
- Spark_Wang2 years ago
Hi,Leo
thanks for your reply
yes,we are using the Stratix 10 E-Tile Transceiver Native PHY.
On the configuration interface, when we enable latency measurement options, the interface shown in Table 45 is added to the ip core.
But the description says " Reserved port. Do not connect. "and the comment (28) in Table 45 suggests referring to the latency measurement section.So we don't know how to use this latency measurement options.
We are using Stratix 10 E-Tile Transceiver Native PHY, can you provide a solution to measure deterministic latency based on Stratix 10 E-Tile Transceiver Native PHY?- LeoFeng2 years ago
Hi Wang,
Sorry for the late response, I was taking annual leave.
I'm afraid we do not support deterministic latency calculation for Stratix 10 E-Tile Transceiver Native PHY IP. As the UG says, the user should not enable those ports in their design.
You can only get latency measurement through CPRI PHY IP if you are going to use it.
Leo Feng
Ok,thank you Leo
BR/
Spark Wang
