Enable the Latency Measurement function of Stratix 10 E-tile Transceiver Native Phy
Hi Wang,
This is Leo.
For the first question, the latency measurement ports are for internal use only, the user should not enable it.
That's why those ports are reserved ports and should not be connected.
For the second question, according to E-tile CPRI PHY IP UG. The reconfig_addr is 19-bit per channel, reconfig_readdata is 32-bit per channel. So each channel will have a total 32 bits data bus instead of 8 bits each.
Leo Feng
Hi,Leo
-----------For the first question, the latency measurement ports are for internal use only, the user should not enable it.
That's why those ports are reserved ports and should not be connected----------
We need to use this latency measurement function, open this port, and then we can read the relevant values through the reconfig interface, right?
