EMIF ip fetches error while simulating in vcs
Dear DChak3,
Thank you for joining this Intel Community.
I believed your design contain Intel® Stratix® 10 HPS EMIF thus you will see this error is generated. It is a known issue as Stratix 10 HPS EMIF simulation is not supported.
You may refer to this KDB link for more details -->
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/emif/2018/error--iossm_bf_cpucputestbench-ihpread-is--x-.html
Aida
Hi nuraidaA
I am not using Intel® Stratix® 10 HPS EMIF instead I am using External Memory Interfaces Intel stratix 10 FPGA IP. It is simulating if I am using this IP with other bunch of IP's. But while I was trying to create libraries using the script provided by quartus. When i select the option from tools>Generate simulator script for IP.
I ran the script and it shows error mentioned above when it reaches to simulate EMIF IP.
Reference snapshot attached. The blue circled one is used in the design.
