Fatimaa
4 years agoEMIF does not have any access to DDR3
I tried to access to the DDR3 via EMIF, but I could not access to the sdram.
Indeed I check the EMIF standalone and in this case I have an access to the sdram but Emif with HPS could not spea...
AdzimZM_Altera
4 years agoHi Fatimaa,
Thank you for using Intel Community.
I need your help to clarify my questions below:
- Which Quartus version that you used?
- Which device that you used?
- Are you facing problem with the FPGA EMIF IP or HPS EMIF IP?
- Any timing violation occurred?
Thanks & Regards,
Adzim
