HBhat2
Contributor
7 years agoElectrical IDLE in Transceiver
Hi, My requirement is keep the transceiver lines in Electrical Idle whenever the Logical Layer FSM goes into low power state. I found that we can select "Enable tx_PMA_elecidle port" under TX PMA ...
CheepinC_altera
7 years agoHi HPB,
As I understand it, when the TX buffer is put to electrical idle, the output voltage should be the common mode voltage. However, I have not physically measured this in hardware, you might need to perform hardware measurement to double check on this. Sorry for the inconvenience.
Chee Pin
