rsing93
6 years agoediting hbm2 example design and simulating the new design.
I m trying to understand hbm2 interfacing on stratix 10 using the example design generated using the ip programmer. I want to change some filss inside the example design and simulate the results to u...
NurAida_A_Intel
6 years agoHi Sir,
By right, user shouldn't re-generate IP again, user is expected to modify design and compile design only. Once user re-generate IP, everything will be reset to default setting in IP.
Aida
