rsing93
6 years agoediting hbm2 example design and simulating the new design.
I m trying to understand hbm2 interfacing on stratix 10 using the example design generated using the ip programmer. I want to change some filss inside the example design and simulate the results to u...
rsing93
6 years agoHi,
I am not able to figure out how to create new simulation and synthesis ip files after changing the LSFR file. Every time I regenerate IPs using the IP regeneration process during compilation all the files are reset to their original form. The new IPs generated do not have the changes I made. The video mentioned by you in your reply does not go clarify that process.
