editing hbm2 example design and simulating the new design.
Hi Sir,
Thank you for the explanation. Appreciated it. 😊
As I understand it, you are trying to change the traffic pattern and referring to this file --> XX_emif_avl_tg_lsfr ( please correct me if I'm wrong ).
Yes, you are able to change this LSFR traffic pattern for testing purpose. You need to create the specific control pattern that required and replace the file in the directory which your LSFR file located.
For additional information on changing the test duration and traffic pattern for the Intel Stratix 10 HBM2 traffic generator, refer to the Intel Stratix 10 High Bandwidth Memory (HBM2) Traffic Generator video, available here: https:// www.youtube.com/watch?v=XLfw12VCm0U.
It help user understand on how to change the test length as well and traffic pattern on the traffic generator for example design. At the end of the video, it demonstrate the simulation results on the changes done on the test length and traffic pattern.
I sincerely hope this helps.
Aida
