mel_tong
1 year agoE-Tile Transceiver PHY Agilex data rate is 10G, but hssi_ehip_lane_ehip_rate is rate_25gx1
Hello,I configured the E-Tile Transceiver PHY Agilex7 IP ; and the Transceiver configuration rules is Gearbox 64/66 ;mode is TX/RX Duplex. TX and RX PMA data rate is 10312.5Mhz; PMA reference clock f...
paveetirrasrie_Altera
1 year agoHello Mel_tong,
Apologies' for delayed response.
I'm able to see what you're referring to. May I know if what are the issue that you're observing?
Because for now I haven't came across this has caused any issue so just wanted to check what is the observation at your end.
