mel_tong
1 year agoE-Tile Transceiver PHY Agilex data rate is 10G, but hssi_ehip_lane_ehip_rate is rate_25gx1
Hello,I configured the E-Tile Transceiver PHY Agilex7 IP ; and the Transceiver configuration rules is Gearbox 64/66 ;mode is TX/RX Duplex. TX and RX PMA data rate is 10312.5Mhz; PMA reference clock f...
paveetirrasrie_Altera
1 year agoHello Mel_tong,
I did try to replicate the issue that you've mentioned but unfortunately I'm unable to see what you're observing at your end.
Do you mind attaching the ip file that you've generated for debug purpose?
Pavee
- mel_tong1 year ago
Hi Pavee,
The zip is 10G IP. At the same time, there is also verilog for related parts.
tong
