mel_tong
1 year agoE-Tile Transceiver PHY Agilex data rate is 10G, but hssi_ehip_lane_ehip_rate is rate_25gx1
Hello,I configured the E-Tile Transceiver PHY Agilex7 IP ; and the Transceiver configuration rules is Gearbox 64/66 ;mode is TX/RX Duplex. TX and RX PMA data rate is 10312.5Mhz; PMA reference clock f...
mel_tong
1 year agoHi Pavee,
I not used E-Tile Ethernet hard ip, I use E-Tile Transceiver PHY IP.
And the parameter settings for this IP core are as follows:
Transceiver configuration rules select: Gearbox 64/66
Transceiver mode : TX/RX duplex
Number of data channels is 1
TX/RX PMA modulation type is NRZ
data rate 10312.5Mhz
reference clock frequency is 156.25Mhz
