HBhat2
Contributor
6 years agoE-Tile Transceiver " Reverse Parallel Loopback"
I want to use " Reverse Parallel Loopback" feature for some protocol analyzer application.
I understood that in L-tile, Reverse serial loopback mode doesn't support for GXT (more than 17.6Gbp...
Deshi_Intel
6 years agoHI HPB,
My understanding on the 0ppm difference is both FPGA Etile and external chip/test equipment need to share with same refclk source else it will induce ppm difference that may cause data loopback transfer failure.
dlim
