rkv
6 years agoE-Tile Ethernet IP Link up not happening
We are working on Stratix10 Development Kit. We implemented Intel E-Tile Hard IP based project. We connected this board with Mellanox board through 100g Twinax Copper cable provided with the FPGA boa...
Deshi_Intel
6 years agoHi,
Based on your issue description, looks like you have isolated the issue to be cable dependent, right ?
Most likely you are dealing with signal integrity issue here. You may want to check the difference between these 2 cables.
- Could be some performance issue due to either cable length or cable quality.
- Or the cable itself is faulty/damaged.
dlim
rkv
6 years agoThere are no issues with the cables, I am getting link in other setups using these cables
