lambert_yu
Contributor
11 months agodynamic configuration issue of fpll from arria 10
Hi, all quartus ip : quartus 191 IP : fpll operation mode : fraction mode For change the frequency of fpll: I modify c0/m/n/k, after configure these register , then use register to r...
JohnT_Altera
11 months agoHi,
Have you try to use the latest Quartus to see if the issue is still observed? Is this only happen in simulation or it is also observed in hardware?
- lambert_yu11 months ago
Contributor
Now I only have tried the quartus 191 and only did the simulation, I will check this IP using quaruts 24.
Contributor
I tried quartus 242, and I met the same issue.
