KRoma6
5 years agoDriver Code for DMA with PCIe Hard IP on Cyclone 10 GX dev board
I am looking for a driver code example for read/writes through DMA with PCIe Hard IP on Cyclone 10 GX. I am following the user guide on programming the configuration registers and setting up descriptor tables but my computer freezes every time I run it. I am using the design example for Cyclone 10 GX PCIe Hard IP with DMA using the Cyclone 10 GX dev board. Looking for open source driver code or a similar example.
1 Reply
- Rahul_S_Intel1
There is a driver code is available during the generate example design , you can make use of it
