DisplayPort_TX IP in image video mode
- 7 years ago
Hi guys,
Finall answer on whats wrong with picture (protocol)at top is video valid signal. It have to be zero in blanking, and it have to be valid when eol, eof, sof and sol occur.
- JoEl7 years ago
Hi dlim,
1)I might described my problem badly - we want to use clock enable at video_im_interface since there is table refering to feature that data don't need to be valid at every clock cycle and you are able to prolong period by deasserting txN_im_valid and slow down output for balancing input fifo. Sorry for wrong interpretation.
2) our end device is generator/checker for now and we are able to see whats going on in cable.
My current problem is that I generate correct data for tx_im_interface but HW checker doesn't see any valid video. As I have attached I generate valid, sof, eof, sol, eol... only thing is that we deassert video image valid on every second cycle as you can see in picture but according to design guide this should not be a problem.
we find that when internal pattern generator is used, MSA params were calculated correctly which is not with HDMI source (same rate only difference is video valid deaserting) but link isn't trained and loop in training mode....so nor generator nor HDMI generate valid output.
