slmel
5 years agoDisplayport Timing diagram for when setting Pixel input mode to Dual or Quad
We are planning to use displayport in out product. In this we need to know the timing diagram when setting Pixel input mode to Dual or Quad. According to user guide,
1. Since 4 pixe...
- 5 years ago
- For the video data transfer over single, dual and quad mode, you can look at at the high level timing diagram in below user guide doc (page 10 onwards - Figure 4,5,6)
- For understanding of detail transaction over certain video resolution across different video pixel mode
- I recommend you to build simple design connecting test pattern generator 2 (TPG2) IP -> Clock video output (CVO) II IP and configure the desired video resolution setting
- Then run simulation to observe the sim waveform directly
- You can learn more about TPG 2 and CVO 2 IP in below user guide (chapter 7 and chapter 22)
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_vip.pdf
dlim
Deshi_Intel
5 years agoYou are welcome !
