DisplayPort RX to 3GSDI TX
It may be a bit overkill for your application but the Clocked video input and Clocked video output in the Intel FPGA video IP suite can be used to bridge between the DisplayPort IP and SDI II IP. The whole video IP suite is worth considering if you have to do some processing in the middle and also need things like color space conversion, chroma resampling, frame rate conversion, change of dimensions, gamma conversion. ...
Hi vgs,
thanks for your answer. with
"It may be a bit overkill for your application but the Clocked video input and Clocked video output in the Intel FPGA video IP suite can be used to bridge between the DisplayPort IP and SDI II IP"
are you saying me that the two IPs afore mentioned can not be linked directly? Or better , It is needed to mandory place something (Clocked video input and Clocked video output) between them in order to allow their communication?
