watari
7 years agoDisplayPort Rx IP can't generate stable recover clock in clock recover module.
Hi community member We'd like to use DP Rx IP as eDP Rx and generate stable recover clock by bitec_clkrec module. We already implemented it into Arria V (5AGXMB3G4F31I3N) which was referred example...
BoonT_Intel
7 years agoHi Sir,
The example design is provided AS-IS basis, it is not recommend to make any modification to it.
Based on the errata sheet, rev D is fixed. Can you share more on how you observe the clock is unstable?
