watari
7 years agoDisplayPort Rx IP can't generate stable recover clock in clock recover module.
Hi community member We'd like to use DP Rx IP as eDP Rx and generate stable recover clock by bitec_clkrec module. We already implemented it into Arria V (5AGXMB3G4F31I3N) which was referred example...
BoonT_Intel
7 years agoHi Sir,
Is the PLL integrate in the example design or you generate it externally?
If it is integrate in the example design, I don't think it is recommend to change the frequency.
If it is generate externally, I will suggest you to refer to PLL user guide to determine the parameters.
Also, refer to Arria V Errata sheet to check it there a known issue that impact PLL with certain frequency range.
